HELP WIPERS AND RADIO WONT WORK !!!!
I own a 2001 mustang gt and the
Wipers Wont work and stock headunit will only show time (wont play radio/cds). I dont think any of my fuses are blown as i checked them just by lookin at em. pls im stumped any help appreciated
Do you have reason to believe these 2 issues are related as in they happened as close as you can tell at the same time? The only thing they have in common is that they run through the same fuse panel and are both hot in accy/run, and if that is the case it seems like there would be a lot more that was wrong. (wipers 30A fuse 2, radio 15A fuse 11 accy/run and 10A fuse 8 always hot)
Without getting into the wiper issue, the radio is powered off of 2 separate leads, one which provides continuous power for the clock and other settings and one that provides power while in accy or run for the actual radio part. The latter is the circuit you need to check.
Former and latter are grammatical terms used to reference items that were stated previously
that is what the Haynes said... wouldn't be the first time they have been wrong. But still, the application is still the same, there is a fuse that powers the radio in accy/run. I would look on my car, but it may not be the same as yours as there were plenty of other changes between 01 and 04.
Fuse 32 Is how I fixed mine
Fuse 32 is how I fixed mine 15AMp
