wide tires with lowered suspension question
just bought a 2001 Bullitt off my sister; she put some wide wheels out back and I love the look, but I want to drop it a little bit; I hate the massive gap between the wheels and fender (always have); I also want the suspension to be stiffer; what are my options as far as dropping the car an inch or so? this car is just going to be my daily driver, so I hope to just change out the springs, but I want a stiffer ride so I don't run the risk of rubbing those wide tires out back; I have looked at the Eibach pro kit and sportline kits; I'm kinda leaning towards them...any suggestions?
I've got the Eibach Sportlines myself running the stock tire size 245/45/17s. The ride definitely got stiffer, but the bumps are a little rougher as well. I've heard good things about the H&Rs as well. Both are good brands. For me the sportlines didn't "slam" the car, so its still completely daily driveable. As for tire size, I do believe you can go 275/40/17s in the front with little to no rubbing, but it varies on different brands of tires. (Correct me if I'm wrong guys) My buds 02 GT came with that size on the front and I dont remember him having a ton of issues. For the rear I think you can go up to 315/35/17. Just my input here.
did you only swap out the springs? the sportlines are the more aggressive drop according to eibach's website; I read several other places you can get away with just swapping the springs but you would want to get some caster camber plates so you don't wear out your inner tires up front; any problems with your tires yet?
Your Bullitt is already about 3/4" lower than a GT, so for reference you want a drop of about 1.75" from the stock GT ride height. The spring rate for a drop like that will be higher, so unless you have a low mileage Bullitt you will probably want new shocks to go with the springs, plus CC Plates are in order also.
Specific springs are pretty much personal preference, so look at the drop and the spring rates to decide what set you want. 4-bolt CC Plates are what you want. I love my Bilsteins, but if budget is tight you might consider Koni STR-T shocks.
Good luck and enjoy the Bullitt!!!
Note: IMBOC.com is another great source of info for your Bullitt.
hey thanks for all the info; I'll definitely get on that site and see whats up; its an 01 Bullitt with just over 80k on the clock; its rides smooth now, but that doesn't really tell me much about the shocks; I think I will definitely do some more hunting around, but right now I'm thinking sportlines with CC plates will do me for a while; then comes the exhaust!!!
on your Bullitt, you can run the Eibach Pro Kit springs with 315/35-17s without rubbing.
A setup I've used in the past on New Edge Stangs is a set of Strange Engineering 10-way adjustable struts & shocks and UPR Pro Series springs (which are actually made for us by Eibach and spec out the same as Pro Kit springs) This setup handles well, has a decent ride quality, and can be adjusted very quickly in a parking lot with no tools.
We carry all of these parts at www.uprproducts.com
Feel free to call us and we'll be happy to answer any questions you have. 561.588.6630
