Old 10-08-2015, 04:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Suspension mods?
Old 03-27-2012, 07:38 PM
04camaroeater
04camaroeater's Avatar
Default Suspension mods?
I am currently sitting on h&r lowering springs and I like my ride height. My question is what should my next suspension mods be to shave some time off of my 1/4 et? I know tires will gain me the most traction but what other mods should I be looking at?
04camaroeater is offline
Old 03-27-2012, 09:00 PM
tj@steeda's Avatar
You could definitely get some LCA's to keep the power on the ground and give you more forward movement.
http://www.steeda.com/store/steeda-a...d-mustang.html
PM if you have any questions or if you wish to place an order.
Best Regards,
TJ
tj@steeda is offline
Old 03-28-2012, 01:13 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
Yup, aftermarket LCA are the next component to upgrade.
FLSFC should be a high priority as well.
Although they are not good for handling, MEGA BITE JR LCA will give you a noticeable improvement in planting the rear tires under acceleration. I had a set on my car before I installed all of my suspension components. THEY WORKED!
TIRES will do far more for your times at the track than all the suspension mods on the planet. Tires before any other mods if track performance is the goal.
TRUEBLUE3934 is offline
Old 03-28-2012, 05:42 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Tires
Control arms
subframe connectors
Shocks/struts
K-member kit
cc-plates
basically in that order^^.
We carry all of these at UPR Products and we know what it takes to make your car hook. We've won literally dozens of championships on the dragstrip, and our suspension works great on the street as well. Also, we offer MF.com members a 10% discount on every part we manufacture.
www.uprproducts.com
UPRSharad is offline
Old 03-29-2012, 09:20 AM
uberstang1
Chupacabra
uberstang1's Avatar
The most overlooked mod that doesn't necessarily improve traciton, but definatly prevents costly repairs when it comes to making a stick 1/4 miles streeter is, GETTING the factory torque boxes welded or supported.
uberstang1 is offline
Old 03-29-2012, 02:50 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
It's true! We carry the torque box plates, which can be bolted in, but we also recommend seam-welding the factory plates AND welding our plates in, if possible.
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension mods?
