New rearend rebuild grinding noise
I've had the car back for a week now, did a full rearend rebuild from Ford with 4.10 gears. It's a 2001 GT AUTO. At first everything was good.
Just today, it started making a grinding noise when coming to a stop. It's fairly off and on. On other threads people are saying it's probably the clutch packs but I had brand new clutch packs installed from the Ford Racing TLok rebuild kit. The grinding noise actually sounds like it's coming from the front, but because of how short it lasts it's hard to pinpoint exactly.
I'm hoping it's just part of the break-in period and that this noise goes away. If it persists or gets worse after a couple weeks then I'm going to have it checked out by the mechanic.
from a stop turn your steering wheel sharply to the left or right all the way then go ahead and take off and note if theres any clicking or grinding noises from the rear.
jack the rear up and spin the wheels and try to hear for anything abnormal.
and finally what I would do is to bounce the rear of the car several times while its in park real good and see if you hear anything, this way you can try to narrow it down to the cause.
I'm trying to track down a noise as well (which I believe to be the LCAs). Listen for it @ 1:00:
http://www.youtube.com/watch?v=Q-Jex...layer_embedded
Sound similar to yours?
NewEdgeStang00,
Who did the work on your differential?
I would strongly suggest taking it back there ASAP. This noise is not part of a normal break-in.
More details. Did it make any noise at the beginning of the week? Do you hear noise under any other conditions? Was the correct fluid used when the work was done? It is amazing how something as simple as the wrong fluid can cause terrible noises from the diff unit.
Good luck and post up any more info you can provide!
NewEdgeStang00,
Probably NOT the same issue for you, but my AuburnPro diff began making a TERRIBLE clunking/grinding noise and sounded like it was going to come apart at any moment when maneuvering at lower speeds. It turns out that the fluid I was using was WRONG!
I had installed Royal Purple Synthetic 140-85(I think). I spoke with an engineer at Auburn, the diff was designed to run a non-synthetic 80/90 fluid plus Ford Friction Modifier. I drained/flushed the Royal Purple and put the basic 80/90 dino oil in and the noise went completely away. I was shocked!!!
I share this just to make a point that the diff was designed around a certain fluid and using something else could cause terrible results. Note: my noise did not begin immediately either. It took a couple of weeks for the noise arise.
GOOD LUCK figuring this issue out!
