Yeah prolly 60lb injectors. IMHO it isnt worth switching until you are into a high boost setup, it would be cheaper to throw a meth injection kit on there for now then do e 85 when you build your motor and up the boost.
^+1. For your setup you would have just as much benefits running 93 and 50/50 meth. You won't need nearly the fuel system you would need with E85 and you can find 93 octane at every corner.
Thanks for the info I just might go with the meth now thanks guys.
