blow by valve
Old 04-27-2012, 09:37 PM
russellthelovemuscle
russellthelovemuscle's Avatar
Default blow by valve
hey guys, i'm about to up the boost on my vortech supercharger from 9psi to 16psi. how can you tell what type of blowoff valve will be best for your type of application? i was looking at the one vortech sells but its almost $300 and moneys always an issue.
russellthelovemuscle is offline
Old 04-28-2012, 09:05 AM
97stanger
97stanger's Avatar
If you want a vortech piece it's going to have to be the mondo valve at 16 psi, and yes they are $300. Are you running blow thru?
97stanger is offline
Old 04-29-2012, 01:57 AM
i don't want the vortech one only because of price and i am running blow thru. i'm thinking of ordering the cx racing universal intercooler kit that comes with a blow off valve but i heard there could be tuning issues with that since there more geared towards turbos
Old 04-29-2012, 07:12 AM
dwtjr3
dwtjr3's Avatar
Im not sure how much boost those cx racing ones can handle. Honestly when running that much boost a BOV is not somthing you want to skimp out on too much. Because if you get one that cant handle the amount of boost you are running you will force that air back into the blower and cause compressor surge.
I have seen a few threads about your setup, do you have any pictures of it? Im interested in seeing your car.
dwtjr3 is offline
Old 04-29-2012, 07:27 AM
oxfordgt
oxfordgt's Avatar
I wouldn't use that cx racing bov with 8lbs.
oxfordgt is offline
Old 04-29-2012, 07:33 AM
97stanger
97stanger's Avatar
yeah man, save up and wait and do it right. Im guessing you have a built motor and a good amount of $$$ invested into it...not a smart move to skimp out on a part and save $100 bucks when it can cause more harm than good. You dont have to get the Vortech Mondo, as there are other options out there but I would wait and just save and invest into a good valve
Old 04-30-2012, 02:14 PM
i've got a ton of pictures of my build. i built it over the course of 3 years with most of the work done in the past 3 n half months. i did some pretty sweet custom work of my own like the wire tuck and relocating the fuse box into the fender with a custom bracket i made so its still asseble when opening the hood. i'm going to try and put them on a site tonight and post the web adress
Old 04-30-2012, 02:32 PM
dwtjr3
dwtjr3's Avatar
Awesome man, I am a big fan of hiding the wires, and when i do a motor in mine ima hide as many as possible. Post pics when you can
dwtjr3 is offline
Old 04-30-2012, 03:27 PM
oxfordgt
oxfordgt's Avatar
I did alot of wire tuck on my old car. I went so far as to cut open the harness and reroute wires to make the wires barely visible.
oxfordgt is offline
Old 04-30-2012, 10:29 PM
97stanger
97stanger's Avatar
so with all that time/money into it why cheap out on a valve?
Quick Reply: blow by valve
