Crazy tire hop... what to do???
Old 09-19-2005, 08:02 PM
97slobra
97slobra's Avatar
Default Crazy tire hop... what to do???
OK i have MM solid lower and MM uppers, MM full legth subframes, stock shocks and quads. And i still have extreme tire hop, its ridiculous. When im burning out in the water box its fine, but when i depress the break and roll out of it, it shakes the hell out of everything. What do you think is wrong? Im running my second set of 555r's and the first set of the tires i never had any tire hop. Why would it start now all of a sudden?
John
97slobra is offline
Old 09-19-2005, 08:04 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: Crazy tire hop... what to do???
You don't need to be in the waterbox for those Nitto's.....
They might still have water on them when you are rolling out of and catching traction momentarily and literally making your rear bounce from the ground.
Dan04COBRA is offline
Old 09-19-2005, 09:10 PM
97slobra
97slobra's Avatar
It will hop wether i burn out in the water or not.
97slobra is offline
Old 09-19-2005, 11:29 PM
00GT00
00GT00's Avatar
ORIGINAL: 97slobra
First thing, take out the Quad shocks. Once you go with better LCA, you are supposed to take them out. If your UCA are adjustable make sure your pinon angle is set right. Also what shocks and springs are you running?
00GT00 is offline
Old 09-19-2005, 11:38 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Agree with 00GT.
If you are having issues with it all the time now, time to can the quad shocks.
Old 09-20-2005, 12:09 AM
racer02GTstang
racer02GTstang's Avatar
i didnt know the quad shocks are suppose to be taken out with better control arms? so even if i have a convertible i can take them out and would i bet better traction? what would i loose with taking them out?
racer02GTstang is offline
Old 09-20-2005, 12:53 AM
00GT00
00GT00's Avatar
ORIGINAL: racer02GTstang
You will loose nothing but gain everything!
00GT00 is offline
Old 09-20-2005, 03:17 AM
Blk_96_GT
Blk_96_GT's Avatar
i thought the quad shocks helped get rid of wheel hop? so when you add the lower control arms you need to remove them? why is this? oh and to help with you wheel hop, here is an expensive way to help, ditch IRS and get solid axle. you will save weight, this guy i know has a 03 cobra and he hates the irs so much wheel hop. that is your problem ---> IRS
Blk_96_GT is offline
Old 09-20-2005, 09:48 PM
97slobra
97slobra's Avatar
I have stock springs and shocks. Im gonna take out the quads tomorrow and see what that does. And i dont have a IRS, they started in 99, mines a 97.
97slobra is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Crazy tire hop... what to do???
