water in oil after PI headswap help me please!!!
ok guys here is the deal.. I did a PI headswap on my car and left a plug outta the back of the driver side head and one in the front upper side of the pass. head and I started it up for about 2 minutes when i noticed oil and water going everwhere so I shut the motor off and pulled the heads off again and found that i have had water mix with my oil somehow and I dont know how that could have happened anyone know what might be the cause could it have been a bad sealing headgasket?...please help me
RE: water in oil after PI headswap help me please!!!
i dont know check you bolts make sure they all are torqued(sp?) down correctly. did you use new head gaskets? they can only be used one time, now that you pulled them off again you will need new ones, again. time to change your oil also so the internals and every thing dont rust
yes i did...i followed it to the letter. But when I was undoing the bolts i noticed that some would ocme loose fairly easy and other i would really have to struggle with.
OIL GALLERY PLUGS You need 2. There on the old heads but there differant sizes. Go to a Ford dealership and get the 99-04 plugs. And they go in the upper corners of the heads.
yep gonna get all that nasty crap out of the engine before I use my expensive oil lol...Im still freaked as to if this is gonna happen again or not....
ORIGINAL: bearster18
jwog666
12-27-2021 08:09 PM
