Steering Column Wiring?
Just wondering, Anyone out there have any idea what wires underneath the column are attached to:
key: Accessory
key: On
key: Crank
Blinker Left/Right switch
Hazard switch
preferably if the wire is directly off that switch (both pos and negative if available) any help appreciated. and if you know of the easiest way to access these, even better. right now im pretty much upside in the seat, head underneath the dash lol gets really confusing when you dont know which way is up.
im about to start runnin my multimeter through whatever i can find.
key: Accessory
key: On
key: Crank
Hazard switch
i've completely (well, nearly) removed the wiring harness from the car. i was looking to eventually re-use the stock hazard, turnsignal switches to retain them.
was going to use the accessory/crank/run key switch as an extra switch. not sure exactly what i want to use it for just yet, as im going pushbutton crank. might use it as a crank cutoff switch, or a coil arm switch.
The wiring diagrams in the shop manual are grouped by system (ignition, stop lights, hazard lights, etc.) not by physical location (steering column, etc,). This means that what you seek would easily cover 10 to maybe 15 diagrams.
I have sent you a PM...
jwog666
12-27-2021 08:09 PM
