will 2006 4.10 gears fit 98 gt?
been looking to invest in some 4.10 gears for my 98 mustang gt auto. i found some that someone was selling 410 out of 06 mustang. will they fit myne? and will there be a good improve in power from 0 to 60?
Originally Posted by motormanimatt
(Post 7978297)
Youre going to also need a tune if you go this route in order to adjust the cars computer and tune the shift points, i recommend a bama tune. Also, im not sure if the 06 gears would fit (i dont see how they could), but i would go the safe route and buy a new gear kit. http://www.americanmuscle.com/fopege4ra.html Doing this you make sure youre putting quality parts in your car and wont harm anything. Only $159 (without tune). Hope this helps! |
Pretty sure they will fit; both cars use an 8.8" rearend.
Originally Posted by xx10Gt
(Post 7978362)
Stock gear ratio in the rear for the 96-98 is 2.73. (3.27 was optional that year). if you go with 4.10's expect a decent increase in pull from the line but also expect a decrease in MPG but that shouldnt matter because after all, its a mustang...
Yes they will work.
Originally Posted by 1998Slow 'Stang
(Post 7978563)
Actually, as the 98 speed sensor is gear driven a tuner WILL NOT correct the speedo, he will need a new drive and worm gear, or a Dallas Mustang Speed-cal (simplest)
(Post 7978809)
yeah, i didnt mean tuner to fix the speedo i just figured for the best bang for the buck type of thing
(Post 7979645)
Misunderstood you then, my mistake. Just didn't want him to think it would fix his speedo and then get disappointed when it doesn't.
Those gears will fit. Just make absolutely sure that there are no cracks, etc... in them. I also believe that used gears from a gear swap aren't the best idea...I'd recommend you buy new...unless they are selling for dirt cheap :)
