Speedometer LED lighting Kit
has anyone tried this kit? Heard of it? Installed it?
LED Speedometer Upgrade Kit
New Product from US Speedo. Change the old boring bulbs in your speedometer to the latest and greatest in LED lighting technology.
Easy Do it yourself Upgrade. Twist in / Twist out
Kit includes 7 Specifically Designed LED bulbs. Exact 12 volt replacement bulbs. No modification required.
Step by step install guide from US Speedo.
Works in most 99-08 Ford F150, Mustang 99-04, 02-04 F250,
3/8" Twist in Base
The above picture is for reference ONLY. The actual items shipped will be base on your vehicle type and color selected.
Professional installation is available with US Speedo. Only $49 (plus shipping)
LED Speedometer Upgrade Kit-Ford $49.99
3/8" Twist in Base
Code:
http://www.usspeedo.com/led-speedometer-kits/
Code:
http://www.newtruckstuff.com/shop/default/interior/led-upgrade-kit/led-speedometer-upgrade-kit-blue-ford.html
I have LEDs in my cluster. I have an aftermarket white face cluster that has a blue film. But from what I understand the stock cluster in 99-04s have a green film so if you were to put in white LEDs it would still glow green. But then I also heard that the stock cluster has a blue film and the stock yellowish lights make the clister glow green. So idk what to believe lol
Stock cluster has a blue film until 2001 1/2. After that 2002 and up have a green film. They also changed the bulb type in this year as well. I know because mine falls on the newer side of 2001 and the parts I ordered for a 2001 were wrong. So be aware that 94-mid 2001 are NOT the same as 2002-2004.
I thought it would be a pain in the a** do replace the bulbs but this makes it look simple. I think I will give it a try.. 1 question though my dash looks green so I imagine after the LEDs it will still look green? Any way to change it? but I do have a green stang though so should I leave it green? But Blue looks super nice!
