turbo oil drain
turbo oil drain
Hey there fellas i was wondering if anyone knows where to run the oil drain from the turbo ?i have an on3performance kit and i forgot to drill the oil pan before installing the kit (big mistake , new to the turbo world) so when i tried taking the oil pan one of the bolts head stripped so i cant take the screw off .. Could anyone help me please i only have 3 days to finish the kit i have to get back to work and only car thanks..
You can tap the oil pan with it in the car, to remove the oilpan with the pickup tube screwing with u, ur probably going to have to remove the k frame to drop the oil pan anyone. Just drain the oil, tape the front of the pan (use alof of grease to catch shavings) when installed run some oil through to push out any shavings that are inside the pan, then plug it all up and fill her back up with oil.
thanx i had to do it on the side on the pan so hopefully thats good enough ? and yeah i tried to take the pan out and yeah i saw that i had to take the k member off so i said screw it and did in in place i just hope is good been on the side of the pan..also could anyone explain to me who exactly the waste gate works and where could i run the boot gauge from ? and where could i find an used wideband gauge at is anyone selling one ? im out of my budget so i need an used one for cheap thanks guys for all your help..
I wish you the best of luck with this, i really do.
The boost gauge needs a manifold source, so it sees vacuum and boost
A wastegate, that works by bypassing exhaust gasses around the turbine blade, it uses a combination of exhaust back pressure, spring pressure and manifold pressure to determine when the valve is opened/opening/or closed
And i might suggest, DO NOT try and cheap out on things like a wideband, that thing is telling you if your car is living or dying....
does this on3 kit come with a handheld tune? Are you getting it tuned?
alright thanks for the input i really appreciate it i really need all the help i can het with this ..i already have everything install except the fuel pump and injectors which i will install tomorrow also do you guys know where i can buy 2 coilovers cause for some reason when i brought the car down my coils just poped and came out where they hook inside the hood lol so now i need new ones but my budget is way passed what i was expecting but thats how this things work.
