What do you think about this TB and Plenum?
RE: What do you think about this TB and Plenum?
i would ask to see the dyno charts and prove that its better, bc theres no way a stock plenium can outpreform a bigger and higher quality plenium like accufab
ORIGINAL: tcuallstar
ORIGINAL: Fallstar01
I'm assuming it's ported. There is noway they are gonna make those claims on a completely stock plenum.
Look at the pictures in the ad, it clearly has much larger openings and smoother surface than the stock plenum.
I don't know whether or not it's better than Accufab but why wouldn't this be possible ??
The can not be better then the accufab, because I highly doubt its 75 or even 70mm for that matter. But for the money it looks like it would work. It is ported and polished do it most likely has better air flow then stock.
He did a good job on P&P. I think he did a tad better than I did on mine. But I think that you'd be disapointed if you paid $100+ for it. You'd be mad at yourself. YOu will barely feel the smallest difference and probably only at WOT depending on your mods/tune.
