grinding T45 transmission - why is this happening?
I have noticed when I try to put my trans in reverse, that it grinds unless I move the car forward a bit first. I also get a grind occasionally when I go into 2nd or 4th.
I am not sure why this is happening, I push the clutch all the way in always. I was thinking of replacing my clutch quadrant with a double hook billet one, as well as replacing the clutch cable and installing a firewall clutch adjuster. I am also going to replace the trans fluid with Amsoil ATF.
Any other suggestions as to why this is happening? The car is a 2000 GT 5 speed with 52k miles on it.
Mine does that occasionally, especially going into first while decelerating if I leave it in 2nd, then try to go to first it grinds and I get made fun of.
So now I go from N, to 2nd, to first. No grinding. Going into reverse I go from 1st to R, no grinding.
Hope this helps, I have a 2000 GT with the same mileage! Craziness!
KingRando
10-02-2015 08:06 AM
