MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   4.6L (1996-2004 Modular) Mustang (https://mustangforums.com/forum/4-6l-1996-2004-modular-mustang-7/)
-   -   solid/solid vs. solid/poly LCA's (https://mustangforums.com/forum/4-6l-1996-2004-modular-mustang/680355-solid-solid-vs-solid-poly-lcas.html)
chitown1211 Aug 27, 2012 06:35 PM
Hey guys. I mistakenly ordered a set of the UPR solid/solid LCA's for my '02 GT. I meant to order the solid/poly version as i think the solid/solid are too "race" for my needs. I will more than likely never hit a track with this car. just looking to improve the stock sloppiness/ wheel hop and take corners decently.
My question is how much harsher are the solid LCA's vs the solid/poly? Is it worth the hassle of returning them? Would not having a rear anti-roll bar kill the street use?
this is what I wanted
http://www.uprproducts.com/mustang-9...trol-arms.html
this is what I ordered
http://www.uprproducts.com/mustang-9...l-arm-kit.html
Are they really that different??? Thanks for any info.
uberstang1 Aug 28, 2012 07:53 AM
I run solid solid, my team z use 1 heimjoint then a metal coller on the axle end. Increase NVH is what you will see, but you will see a good amount of NVH with the solid polys as well.
Jazzer The Cat Aug 28, 2012 08:44 AM
^ agreed!
Either of those LCA's will work fine, but you are just introducing more NVH than needed, based on your needs. If you can return them for the ones you wanted, I would do so.
Jazzer :)
© 2026 MH Sub I, LLC dba Internet Brands
