2002 4,6l v8 automatic ??
hi, sorry for bad english.
im getting a 2002 mustang 4,6l v8 automatic, and i was wondering if i put the transmission in, lets say 2nd gear would the car change gear if i rev it to high ? or will it cut out(revlimiter). um just thinkin if i would want to take a burnout or drift, would the var just stay in second gear or ?
thanks.
thanks.
I think if you were to put it in the '2' spot, past the 'D' for drive, then that would be the highest gear the transmission would shift into. This means if you put it in 2 and try to max out, then the transmission would not shift into a higher gear and as a result would hit the rev limiter.
also "2" on the selector will lock you in second gear, no first third or overdrive, even from a stop
