Idle Troubles!!! Help
Ok, did some more tinkering today- checked the throttle stop screw and that was fine. Then, I went to check the TPS voltage- turns out that it was off and was causing the high idle. I twisted the TPS on the TB and it idled perfectly! Problem solved!
