Power top is currently a manual & all 4 windows stuck UP
I am going to try the "press button, slam door technique" I read about multiple times in these forums, but I have a feeling my issue is greater than that fix...
The convertible top easily folds up/down manually; all the hydraulic hoses look great; all the hose fittings look great.
All 4 windows are stuck UP.
I noticed that the Parking Brake sensor thing (has two wires connecting to it and a spring-loaded button) located under the center storage bin above the driveshaft tunnel had both wires cut. So I re-attached them, but still no power top.
The strange thing is that whether I press the window buttons or the power top button there is ZERO sound, like there is no electrical signal being sent/received to any motors.
Any ideas?
Any ideas?
Just got the car back today from the shop where they seem to have worked out the electrical gremlins.
They said the top components all tested out fine but needed a new rocker switch, which I bought and will put in tomorrow myself. Also told me the front driver window regulator was bad, so I'll be buying and installing one of those too.
(knock on wood) Looking forward to having a power top and power windows too.
CarGuyZM10
08-31-2015 07:08 PM
Mustang Sally72
08-11-2015 07:54 AM
