Quick question for 99-04 GT auto trans guys
Old 11-14-2012, 03:20 PM
  #21
Fivaldrood
Fivaldrood's Avatar
Originally Posted by rygi23
did you install the metal exhaust gasket/spacer on the pass. side between the manifold and the h-pipe? Nothing really hurting if leaving OD off until you get up to speed, but not necessary to leave it off until real hwy speeds. Just turn it on 45/50 or so if your not trying to accelerate hard. OD isn't just a converter lock-up. You should feel the converter lock-up with the OD turned off even in 3rd gear under easy acceleration, the rpms will drop a few hundred as if it's going into another gear.
Dont mean to highjack but does anyone happen to know the part number and cost for that gasket? I put on my O/R H pipe not long ago and think I have an exhaust leak from the Manifold/Midpipe connection.
Fivaldrood is offline
Old 11-14-2012, 07:41 PM
  #22
rygi23
rygi23's Avatar
If you didn't install it you most likely do have a leak. Part # XR3Z-9450-AA. Got mine from rockauto, they were the cheapest. Can't remember how much but it wasn't a lot.
rygi23 is offline
Old 11-14-2012, 11:24 PM
  #23
Fivaldrood
Fivaldrood's Avatar
Is it the Exhaust Flange Gasket?
Old 11-15-2012, 09:40 AM
  #24
rygi23
rygi23's Avatar
Correct
rygi23 is offline
djbigskrilla
09-20-2022 01:04 AM
richard1027
09-08-2015 01:24 PM
Lee1911
09-01-2015 02:12 PM
kdryan
08-21-2015 04:01 PM
Stilz
08-18-2015 09:40 AM
Quick Reply: Quick question for 99-04 GT auto trans guys
