Transmission Fluid
Transmission Fluid
I want to do a transmission fluid change, and I was reading the Haynes manual on the procedure, and it only shows removing the fluid from the pan and not from the converter. I want to completely remove the old fluid in the converter as well, so it is possible to get the fluid out from the converter? is there a drain plug?
Also, if I am able to get the fluid out of the converter, how do I add the fluid to the converter? because I don't want to start the car up without some fluid in the converter, or will it not be a problem without any fluid in there.
The only way to get most of your fluid out is a trans flush and it's a touchy subject on a car with higher mileage cause of all the dirt and debris inside the tranny being pushed around causing problems. For the most part everything usually works out. We do 8 quart flushes on Toyotas , but a transmission typically holds around 12 quarts leaving 4 old quarts still inside. But if it gives you piece of mind then thats all that matters.
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
