Where to start?
Where to start?
I just saved an 02 GT with a 5spd manual from Houston before Hurricane Rita hit (sat in 14hrs of traffic to get it home too) and now im ready to start tweeking it.
I have no idea where to start....
If i was to do gears should i go 3.73 or 4.10... Im only lookin to play around on the street.???
What kind of exaust (Brands)... I like a deep sound...but not to bad at highway speeds ???
Which intake will give me the most hp???
What should i do chip wise???
I do know my way around an engine but im not sure what to put in it..... Can u guys help me out?
RE: Where to start?
I see that you are a noob so I will take it easy, Here is a link that sould answer most if not all fo your questions. If you still have questions after reading all info in link try a search first because most likley your question has been asked before and has been answered about a 1,000,000 times over. but if you still have not found the answer you want feel free to ask your qquestions
Here is the link: https://mustangforums.com/m_617221/tm.htm
RE: Where to start?
the gears is a personal choice.. if you do alot of freeway driving go with the 3.73's.. but if do alot of town driving then go with the 4.10's they will be more fun either way..
the exhaust.. depends on how loud you want it and if your going to through a aftermarket h or x pipe on. the magnaflow set up sounds great also alot of people are raving over the slp's lm1 and lm2.
intake.. get a demolet tuneable one for sure.. they are a abs plastic and dont get as hot as the metal ones that get to hot to touch
chip wise.. you should get a programmer, either a diablo preditor or a sct2.. either ones going to run you about 350. but this will take care of alot of different stuff you going to have to deal with down the road..
hope this helps you out
RE: Where to start?
4.10 gears all the way. i do quite a bit of highway driving so i took everyone on here's advice about getting 3.73s. boy was that a mistake. i want 4.10s soooo bad, but don't want to dump $500 on another gear swap.
RE: Where to start?
if you look around they have combo packages with gears and a programmer, you will probably save money buying those at the same time bc you have to get your speedo recal done and you can do that with a programmer, so you dont have to pay a shop to do it for you
dalefrancis88
09-11-2015 07:15 AM
