Removing shift boot
RE: Removing shift boot
unscrew your shift **** (just twist it counter-clockwise). then grab the plastic that surounds the boot and pull it toward you. be careful but your going to need to pull it kind of hard. the boot is connected to this plastic and it will slip off the shifter arm. You will need to unhook the accessory outlet (just press a screwdriver into the little leaver thing)
jwog666
12-27-2021 08:09 PM
