Performance Mods help, new owner
Old 02-08-2013, 03:26 AM
907GT
907GT's Avatar
Default Performance Mods help, new owner
2001 Mustang GT. Before I starts it's in automatic I didn't choose but just found this vehicle at the dealer. 49k miles paid $8.7k for it, I want to just do some simple bolt ons for a little more performance then go for appearance. Not looking for supercharger or anything. So far from research and asking around I've got in mind, new gears (3.73 or 4.10??), upper plenum and throttle body (should get throttle body spacer?), underdrive pulleys, tune. Already got exhaust and K&N CAI, been researching shorty headers but wondering if they can be installed with my current exhaust which I don't know what it is because I bought it with it on. ADVICE/SUGGESTIONS
907GT is offline
Old 02-08-2013, 06:18 AM
xx10Gt
xx10Gt's Avatar
well, first off you might want to check out 4.10 gears if youre not planning on going FI. more bang for the buck. the tuner will help dramatically considering its an auto, and youll need one anyways to calibrate the speedo.
Throttle body/throttle body spacer yields very minimum gain, so it shouldnt be at the top of your list. Underdrive pullies dont create power, they "free up" power which is not good for use if you plan on using aftermarket stereos.. etc.
As far as shorties, they also yield very little gain if any but can help your sound slightly. If you have the stock midpipe or an aftermarket midpipe that is standard length they will bolt up. hope this helps
xx10Gt is offline
Old 02-08-2013, 07:17 AM
907GT
907GT's Avatar
Yeah thanks that helps. So I'm thinking now research some 4.10 gears as long as my automatic can handle them, throw on the plenum/throttle
Body and such a little down the road and get a tune. Out with the pullies and headers for now
907GT is offline
Old 02-08-2013, 10:48 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Read Mods for beginners... and Where to start with bolt-ons... two "stickys" at the top of this forum...
cliffyk is offline
Old 02-08-2013, 10:52 AM
TRexGAWD
TRexGAWD's Avatar
Most shorty headers are a direct replacement of the stock manifolds.. So if you still have the stockers you should be fine.. Long tubes would require a different mid pipe..
TRexGAWD is offline
Old 02-08-2013, 11:00 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
And all shorty headers are just eye candy.
The tubes are not even close to long enough to do anything that the stock manifold cannot do. Headers 101...
cliffyk is offline
Old 02-09-2013, 07:26 AM
luke1333
luke1333's Avatar
put longtube headers and a midpipe on it with some 3.73s!!
luke1333 is offline
Old 02-09-2013, 09:04 AM
Luke13
Luke13's Avatar
Are you looking at letting a shop do the install work, or are you looking more for projects that you can do in your free time?
Luke13 is offline
Pyrate Dave
09-10-2015 07:30 PM
Roush05
09-10-2015 12:23 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: Performance Mods help, new owner
