bad 99 cobra track times. why?
#21
RE: bad 99 cobra track times. why?
I take no offence to being a "bad driver" right now. I'm still stuck on racing like I did my FWD n/t talon.. which is a completely different style of launching. I'm going to the track again in 2 weeks and will take some of the advice from here with me.
#22
i agree w/ everyone on the 60' times affecting your times, but i think you probably have more problems than that. you should be trapping around 100-103 depending on elevation regardless of your poor '60 times. makes me think that there's something mechanically wrong. to see if you've had the "fix", call 1-800-FORDSVT and give them your VIN. you can also check your intake manifold for a green or blue dot (usually near the alternator). get it running right, then let the mods begin. (start w/ 4:10-4:30 gears. you won't be sorry).
#23
yeah I called SVT this morning and they said "the fix" had been done as well as the other recalls. I don't really understand what you're saying about the trap times because the "wasted" length of the track due to my bad launch is taking away from an increased mph by the end.
#24
on the contrary, go bolt a set of slicks and take a run. your e.t.'s will drop considerably, but your MPH will remain relatively constant. MPH is directly proportional to your amount of horsepower, as opposed to your e.t.'s which are proportional to how fast you can get from point A to point B. Unless you are very high above sea level, there is something wrong. my next suggestion would be to go to autozone, or the like, and get a diagnostic scan. won't cost you anything, but see if you're pulling any codes.
#25
ORIGINAL: ourformerselves
Sorry, didnt see taintedme's post, he is also 100% correct.
#26
I went to the track 2 weeks ago and still could not get a good time. I launched around 1800rpm, had 3 or 4 small chirps during takeoff. I lowered the tire pressure to 25psi in the rear.
Here was my best time:
60' 2.397
1/4 14.941
mph 95.41
This was my best time @ the track time before.
60' 2.453
1/4 14.966
mph 95.33
I'm going again to the track on Friday to work on getting some better times. I installed the JLT CAI last week.
Here's some factors I believe to be contributing to my bad times: (comments welcome)
altitude = 2500ft
tires = Dunlop SP Sport FM901
Independent Rear suspension?
Convertable = more weight?
Me = #1 reason. still trying to adjust to RWD launching.
60' 2.397
1/4 14.941
mph 95.41
60' 2.453
1/4 14.966
mph 95.33
altitude = 2500ft
#28
60' 2.397
1/4 14.941
mph 95.41
60' 2.453
1/4 14.966
mph 95.33
altitude = 2500ft
60' 2.397
1/4 14.941
mph 95.41
60' 2.453
1/4 14.966
mph 95.33
altitude = 2500ft
Definitely get a scan for engine trouble codes... and just do some basic checks, fuel filter, air filter... Bad A/F ratio possibly which is causing you to not have as much power as you should.
#29
ORIGINAL: ZW99GT
No sir. Dont aruge with me please, we had had so many heated discussions about this. Your taction(as long as u dont let off) will not affect ur trap speed. I have time slips that prove this. The time u spent spinning actually leaves u with more track than if u would have hooked up. With the extra track, u can get up to speed. ( i dont really know how to explain it)Ask anyone on here with alot of track experience(JD1969 specifically) and they will tell u the same. Trap is directly related to horsepower, not traction!
At the end of the track you are moving FAST... so in the span of 60' at the end you accelerate maybe like 1MPH... so what this translates to is that whatever happens on any given 60' section of track including the first 60' has basically no effect on your MPH... as this is a function of power-acceleration over the whole track.
