Tranny swap question
Old 03-04-2013, 05:41 PM
school boy
school boy's Avatar
look in post 10, its the two bolts in the bell housing of trans, behind the oil pan;
http://www.lincolnsonline.com/forum/...ad.php?t=71572
school boy is offline
Old 03-04-2013, 05:42 PM
school boy
school boy's Avatar
also,
http://repairguide.autozone.com/znet...52801e575d.gif
Old 03-04-2013, 06:13 PM
aframe
aframe's Avatar
Ya i found those i just thought they were plugs not bolts.....i was hoping there was another access....but thanks those attachments did help
aframe is offline
Old 03-05-2013, 01:51 PM
school boy
school boy's Avatar
those converter bolts are a pain, just make the converter is seated on the input shaft of the trans properly. You will know if its not upon start up. engine wont even turn over. an easy way to tell if its seated when bolting the trans to motor, there will be a small gap between the flex plate and converter.
Old 03-05-2013, 07:17 PM
aframe
aframe's Avatar
I am still trying to get the transmission out......do i have to take the converter bolts out before i drop the transmission or can i drop the transmission and then take the bolts out?
aframe is offline
Old 03-05-2013, 08:22 PM
aframe
aframe's Avatar
I also just read somewhere that i have to turn them clockwise to loosen them......im about to just pay someone to do it im going crazy
aframe is offline
Old 03-06-2013, 01:33 PM
school boy
school boy's Avatar
you can leave the converter on the flex plate but the trans will have to slip back from the engine for the input shaft to slide out of the converter. prepare for big trans fluid mess cleanup. converter studs should be easy to get to now. I forgot to mention, remove all spark plugs so you can rotate engine to be able to remove converter bolts.
the converter nuts spin off like a standard nut, counterclockwise.
Old 03-06-2013, 05:11 PM
aframe
aframe's Avatar
You have been alot of help i appreciate it.....but before i strip these im gonna pay someone else to do it
aframe is offline
Old 03-06-2013, 07:48 PM
school boy
school boy's Avatar
I don't blame you, ford couldn't be like gm's 4l80e and have a big access plate.
67LimeCoupe
09-30-2015 04:46 PM
04stangman
09-17-2015 01:45 PM
97SN95GT
09-13-2015 09:45 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Tranny swap question
