I installed new pulleys today and my alternator pulley was rubbing. Is there a washer that goes on the bushing to keep it from rubbing and if so can i order one from steeda? Any help is appreciated
Every UDP I've seen has been lighter than the stock pully they are replacing. The entire point of UDP's is to reduce parasitic drag. They should be a little bit larger than the stock ones as well
