4.6 Rod & Journal Bearing kit?
Old 03-21-2013, 07:12 AM
infine0n
infine0n's Avatar
Default 4.6 Rod & Journal Bearing kit?
Hello,
I have a 96 Mustang GT that we have just finished doing the complete P.I. top end swap, only to find out now that my rod and/or journal bearings are bad in the bottom end.
Can someone recommend me a high quality bearing kit to use on my 4.6?
I have searched Jegs and Summit, but cannot find anything. Maybe I am not looking with the right keywords?
Thanks
infine0n is offline
Old 03-22-2013, 04:25 PM
infine0n
infine0n's Avatar
bump...
infine0n is offline
Old 03-22-2013, 06:33 PM
BraMas
BraMas's Avatar
Are you saying you cant find a bearing kit to rebuild a 4.6
I had no problem finding kits on both those sites when I was rebuilding my engine
BraMas is offline
Old 03-22-2013, 07:05 PM
uberstang1
Chupacabra
uberstang1's Avatar
I'm a fan of clevite
uberstang1 is offline
Old 03-31-2013, 07:52 AM
infine0n
infine0n's Avatar
Just to be 100% sure, I am going to post a couple links to the kits I need. It appears they sell the rod bearings, and main bearings in two separate kits.
Main Bearings:
http://www.summitracing.com/search/b...ew=ProductName
Rod Bearings:
I imagine the H-series would be the route to go? Wondering also if summit is the best place to get these parts from? Maybe even eBay if it is significantly cheaper?
Thank you for the input guys, I appreciate it!
P.S.
Here is a very short video clip of how she sounds right now.
infine0n is offline
Old 03-31-2013, 08:04 AM
infine0n
infine0n's Avatar
update:
here are links to the Clevite H-series coated bearings.
My question now is which kit to get? I know I don't need any special sizes other than standard, but there are different types of main bearings. Tri Metal, Half groove, and I'm not sure what TM-77 means?
Main bearings:
http://www.summitracing.com/search/b...s?autoview=SKU
There is one one choice for Rod Bearings, so that one is easy
Rod bearings:
Thanks!!!
infine0n is offline
Old 03-31-2013, 10:45 PM
infine0n
infine0n's Avatar
BUMP.
I need to get these parts ordered so we can get my car back in shape.
I know which manufacture and which kit series I want (Clevite H-series), but I don't understand the differences between the types of these main bearing kits. Can someone please explain this to me, so I can order the correct set for my application? The car is a stock bottom end 96 GT 4.6L.
infine0n is offline
jwog666
12-27-2021 08:09 PM
jrrhd73must
10-02-2015 09:17 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
UrS4
09-30-2015 10:13 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: 4.6 Rod & Journal Bearing kit?
