tire sizes and clearance
Old 04-01-2013, 01:53 AM
josh0002
josh0002's Avatar
Default tire sizes and clearance
this is a bit of a stupid question but I was wondering if I can fit 255/40/17s on my stock rims (yes they are 17inch rims) I'm just worried about clearance and rubbing more on the front than the back I ask because I want a good sticky autocross tide and well they just don't make then in the factory 245/45/17
Posted from MustangForums.com App for Android
josh0002 is offline
Old 04-01-2013, 04:24 AM
TRUEBLUE3934
TRUEBLUE3934's Avatar
What type of tire are you planning to run for autox?
Lots of guys run 255-40-17 on the 8" rims. However, I would definitely seek out a 245-40-17 tire that will be better supported by an 8" rim. It would feel tighter, more responsive, and more accurate.
I'm assuming that you are running the car in stock class.
TRUEBLUE3934 is offline
Old 04-01-2013, 09:45 AM
Luke13
Luke13's Avatar
255 wide tires shouldn't cause a problem on the front, I believe you can even put 275s up front with a 9" wide rim.
Luke13 is offline
Old 04-01-2013, 11:44 AM
josh0002
josh0002's Avatar
I'm deffinatly not running stock class not entirely sure what class I will be in this season but assuming a st or sm class have cai headders and x pipe looking to do a full suspension mid season
josh0002 is offline
Old 04-01-2013, 01:53 PM
JC316
JC316's Avatar
I run 275/40/17's on all 4 corners with no rubbing issues. A 255 will fit fine. A 255 should fit an 8" wheel just fine.
JC316 is offline
Tivo304
08-28-2023 12:19 PM
2007CalSpec
09-09-2015 05:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
Quick Reply: tire sizes and clearance
