difference in intercoolers
Old 05-03-2013, 05:59 AM
bizarre660
bizarre660's Avatar
Well I feel a little better that I'm not the only but spending this much on it. When the guy told me 1750 I thought he was crazy. Did anyone change the intake plenum and throttle body too? Or is that a wasteful upgrade?
bizarre660 is offline
Old 05-03-2013, 06:51 AM
97stanger
97stanger's Avatar
every little bit helps. With a boosted motor look into a 75mm throttle body and a high volume plenum. What manifold are you going to run?
97stanger is offline
Old 05-03-2013, 07:25 AM
uberstang1
Chupacabra
uberstang1's Avatar
Check forum classifies as well can probably find a deal on a cooler.
uberstang1 is offline
Old 05-03-2013, 09:36 AM
bizarre660
bizarre660's Avatar
awesome ill check the classics.... i was actually going to ask wheres a good spot to buy this stuff. well i have the sock manifold. is something like a roush manifold any good? do you run a stock manifold? i didnt even think about replacing that.
Old 05-03-2013, 11:54 AM
97stanger
97stanger's Avatar
Is this on a stock motor? Stock cams? Would need more info on your setup. But if $ is a concern, which it seemed like it is...now you are getting into swapping manifolds, gaskets, probably new rails...etc
Old 05-04-2013, 04:24 PM
bizarre660
bizarre660's Avatar
yea i think getting into the manifold might be to much for me.... im not to great with engines, but im trying. i think i am going to go with the vortech intercooler (air to air) 75 mm trick flow tb and plenum and get a smaller pulley... something to get around 12 psi.... i was thinking about getting a bike but decided to use the money on the car. hey 97, thanks so much for the help. unfortunately, im the only person i know into cars and the closest shop to me is like 80 miles. so this week im ordering parts!!!
Dokilar
15
10-16-2015 08:13 PM
Bokeo
10-10-2015 08:28 PM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: difference in intercoolers
