Oil blowing out RADIATOR. No oil in block, no coolant in oil
#21
I'm glad I found this thread ,,,, I'm starting to get traces of oil in my coolant , I'm not a happy guy right now but I'll defiantly be looking more into the oil filter adapter plate before I start ripping off the heads.
#22
I am hoping to find the issue without having to tear BOTH heads off. I've spent a lot of time studying this since it happened and it is a very slow leak. The plate didn't help me stop the leak in my case. If it is one of the heads I wish I could find out which and just pull that one instead of both.
#23
How much oil is it actually going through???? I've just noticed this happening to mine and it's really bothering me ,,,,, if it were a head gasket wouldn't a little coolant blow past the leak when the engine is still hot and the rad is still under pressure but the engine not running ??? I see no antifreeze in the oil at all , but small amounts of oil in the rad ?????
If I were to add some oil dye it should show up in the antifreeze to would it not ???? Also gonna finish this stint at work and do a compression test , if it is one of the head gaskets it should show up in the test too.
#24
Its not going to show up on a compression test if you're not getting coolant in the oil. Itll likely be a jacket non cylinder related. A leak as small as this is going to appear as a slightly worn ring at best.
#26
Any reason why this wouldn't fit my 98 gt? http://bit.ly/11wCYnb
I need to try some cheap gaskets first to see if that really is the issue.
bradleyb
11-27-2015 07:50 PM
