need some help
need some help
so I got a set of bbk shorty headers and x pipe. I get the headers in and go to set the eng back down on the motor mounts and the dame things don't fit. the passenger side header sit's right on the mount and right up against the ac line. called bbk they have no clue. so I started digging around the web and found one guy that had this same issue and he got the Urethane Motor Mounts but he did not say if it helped. so this is what I am going to do
1. get the Urethane Motor Mounts
2. get the QA1 Tubular K-Member
and try this again
what do you guys think??? I wasted 15 HR fighting this
and try this again
will to me doing the job right is not a waste of money. and I have the money to spend on the car. and there was no way a BFH was going to fix this I needed 2'' I need more room and I put the stock ones back in I'm not going back in there till its perfect.
Then it's all you, just found it humorous that BBK had no clue. The same song and dance they fed me. I needed no where that much to clear the strut tower where mine were hitting. Only needed a 1/2"....
Hey, good luck with that
