New to me car
Hey Gary, the odometer was fairly simple, just remove the trim from around your gauges (a couple screws and clips), then there are 4 screws holding the cluster in the dash, carefully pull the cluster out and disconnect the two wire harness from the back. look at the back of the cluster, you will see a small "ribbon cable" of about 6 or so wires, carefully take the connector off the pins then re-insert it. then put the cluster back together. I read on here that sometimes there is a broken solder joint on the circuit board that can cause the same issues but I didn't see one, it was just a dirty/corroded connection. took about 30 mins to do from start to finish.
Appreciate the instructions.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
