jmod help
No not the valvebody! The seperater plate that sits between the valvebody. Its a very popular mod and its designed by the engineer that made our tranny. So yes hahahahahahah.
Does your O/D off light start flashing even when you don't turn it off manually?
@Stevo it's a known cheap mod to get the same effect as buying a shift kit or a performance valvebody if done correctly. It's fairly simple to do if you follow the instructions correct though I'd never modify the valvebody myself. I'd rather spend the $300 for the valvebody than having to replace the entire transmission.
