If you're going with the black out theme. There is a lot you can do...
Blackout emblems and side reflectors
Black out in between the tails and the 3rd brake light would really clean up that rear end. And pull off that dealership vinyl on the decklid.
Hahah, when I got my car the dealership had put those domed letters and ford logo on it and I peeled those damn things off before I even drove off the lot.
I agree with everyone else. Everything looks good except for the black side scoops. And I was thinking about blacking out my own decals. I've already done it on the back but I have yet to do it in the sides. Now that I've seen how the sides look like I'm gonna do them for sure! Also you should black out your deck lid too! It really makes a difference on the overall look of the car and it's pretty easy to do. Since you've already done your rear bumper and side scoops it should be pretty much the same process. As far as the grill delete, someone in my neighborhood just took out the entire grill but the bracket for where the pony used to be is still showing. Maybe you can figure out a way to at least cover that up.
Idk about you guys but i like inserts on the back, it makes it stands out more. And the idea of cutting the honeything off is the best idea so far. + you can cut it in an interesting way
Well you thing its gonna be this way, if i just cut it then ull be able to see all the inside stuff which is not pretty, well unless you wanna cover it with something then yaah maybe.
The inserts in the back is cool it's just the blacked out side scoops that kind of sticks out like a sore thumb. And if you want to see how a the front looks like without the honeycomb check out the new edge Mach 1.
Thanks brotha!!! Nothin else to do to her unless I wanna mess around and throw some vinyl on the roof and possibly pillars. I work at a vinyl shop at the moment so it's just cost of vinyl...
