air conditioning problem
I was having problems with my air conditioning not blowing cold, so I went to refill my refrigerant, but when i went to read the gauge after 3 minutes of running, the compressor would come on, the gauge would rise to approximately 45 PSI, then the compressor would turn off and the pressure would drop immediately. Is the system overcharged? Or is there some other problem?
If the system is to low, there is a low pressure switch to shut down the compressor. Adding coolant will bring it up so the switch stays on. Just follow the instructions on the can and it should work.
DrunknRuckus
08-23-2015 10:05 AM
