installing clutch disc onto input shaft -is it supposed to touch guide? (pics inside)
Old 07-03-2013, 10:44 PM
Vertigo_GT
Vertigo_GT's Avatar
I see, thanks for explaining.
Vertigo_GT is offline
Old 07-03-2013, 10:58 PM
RMK01GT
RMK01GT's Avatar
Originally Posted by kingrukus
Okay - would I be able to do this myself? Or would I need a transmission shop to check this?
I am a complete newbie to this type of work.
You would be able to do it by yourself if you; have a dial indicator/mag base, and have the transmission seperated.
Find a solid place to mount a mag base preferably onto the housing of the transmission. set the dial indicator perpendicular to the shaft and rotate it all the way around watching the dial. your looking for any movement on the dial indicating a bent shaft. you will want to use the smooth shaft as you will have a hard time reading off the splines
good luck
RMK01GT is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Jskeezy84
09-08-2015 01:40 AM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
Quick Reply: installing clutch disc onto input shaft -is it supposed to touch guide? (pics inside)
