T-45 fluid change
RE: T-45 fluid change
Not sure about the drain plug, I've been trying to figure that out as well, I believe it's an allen key plug on the side of the transmission. It's so that you only fill the trans up with fluid to that point like it's supposed to.
Oh, and Pennzoil Syncromesh. Period.
So much easier just to take off the shifter and fill it from the top instead of trying to pump it into the side of the tranny. I always just make sure to use silicone seal when I put the shifter back on.
ORIGINAL: Tim37
it is a 3/8 ratchet if i remember right there is a upper one and a lower one. the lower is near the rear of the tranny the upper one is on the right side closer to the center.
Really? Sweet... that's much easier.
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
