water temp gauge install
I ordered a SVE water temperature gauge, mechanical. where do i install this at? on my F150 4.6, I had it where the stock sending unit was in the intake manifold with no problems. could i use this spot on my mustang, or will the computer not get correct readings?
Well more digging around shows its best to leave the factory sending unit alone. I don't have heat in my car, so my heater core is bypassed and both heater hoses are connected together with a coupler. could I just get a T fitting or something and use that location?
Drivers side of the block is a plug. You can put it there and it will give you a reading albeit a tad warmer as 7-8 don't have the flow of coolant like 3-4 do.
