EGR valve
RE: EGR valve
Yeah, that should rule out the MAF. I would try putting in the stock MAF, disconnect the battery for about 10 minutes, then reconnect and see what happens. I assume you also checked your vacuum regulator and checked for leaks, right?
RE: EGR valve
ORIGINAL: Emann0007
okay, so I have replaced the EGR valve and the sensor and again the check engine light has come on reading EGR valve flow excessive WTF do I do now?
Those switches get stuck open a lot and that causes the EGR valve to get stuck open. Not because the EGR valve is bad, but because the switch is telling to open all the way.
http://www.motorage.com/motorage/art...l.jsp?id=54993
Look at 2000-2002 Models towards the bottom of the page. Those codes also indicate a problem with the sensor but are not as common as the ones I mentioned above.
RE: EGR valve
ORIGINAL: sprostang
RE: EGR valve
I know that it is only temporary. But when changing the MAF, as well as other parts, your supposed to disconnect the battery to reset the computer when using a new part. But anyway, I did a little research on this problem because I was curious for my own good and from what I came up with sounds like your right about the DPFE sensor.
ORIGINAL: Derf00
That will only clear the code temporarily. It will come back until that DPFE switch is replaced. I've had a personal experience with it and so have a couple of people I've known.
ORIGINAL: sprostang
