2003 Ford Mustang GT PCM issues
Old 02-18-2014, 01:19 PM
heather_marshall_08
heather_marshall_08's Avatar
Default 2003 Ford Mustang GT PCM issues
I have a 2003 4.6 GT. The theft light started going irractic so we took it to ford dealership. They diagnosed it and told me the PCM is bad. Weird thing is we bought the car crank and drove fine. We had it towed home due to exhaust. After we took if off flatbed and low and behold would not run. The car had the wrong size battery on It and hood would not close. So I am wondering that would cause it to ground out and go bad. Also we had got snow and rain and wondering if the liquid could have got on it and shorted it out. My floorboard was damp. Please help. Trying to fix myself due to FORD trying to charge me 1500. Just to change out pcm.
heather_marshall_08 is offline
Old 02-19-2014, 10:24 AM
JeffBall
JeffBall's Avatar
I feel like it doesnt work like this due to PATS, one of the more experianced people might chime in on this and correct me... but maybe grabbing a PCM from a junked mustang... you would prolly need a tune to turn off PATS. or if you were lucky enough that the key was left with the junked car.
JeffBall is offline
Old 02-19-2014, 02:14 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The PATS type C system used in the '99 to '04 GT incorporates the PATS controller into the instrument cluster; the cluster and PCM are linked by a shared security ID programmed at the factory. If either the cluster or PCM are changed the security ID must be reset. It is mostly only Ford dealers that can do this.
An alternative is as suggested above, disabling the PATS in the tune; however if the PCM is bad that may not accomplish anything.
OP, PM me if you like--I can bench test your PCM to eee if it is bad, and if not force feed it a tune with the PATS disabled, I also have a 2003 PCM with the PATS disabled that I no longer need and will sell at a very reasonable price...
cliffyk is offline
Old 02-26-2014, 09:27 PM
heather_marshall_08
Thanks! The pats system locked down due to the pcm burning up.
Old 02-26-2014, 09:28 PM
heather_marshall_08
The pcm burned up causing the pats system to lock down. We replaced pcm and had it reprogrammed. All is good now. Thanks!
Old 03-14-2017, 10:43 PM
Royce Souza
Royce Souza's Avatar
Default pcm issues
after you replaced the pcm, you said had it programmed. How and who did reprogramming?
what did you have to do?
Royce Souza is offline
Old 03-18-2017, 10:48 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
From post #3 above
cliffyk is offline
Old 03-20-2017, 06:54 PM
WJL
WJL's Avatar
Very nice Cliffy
WJL is offline
Old 06-26-2017, 01:21 AM
Sacer
Sacer's Avatar
It's cool.
Sacer is offline
Old 01-15-2020, 09:43 AM
Duane Frazier
Duane Frazier's Avatar
do you by chance still have the pcm with pats disabled??
Duane Frazier is offline
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
08-10-2015 01:44 PM
Quick Reply: 2003 Ford Mustang GT PCM issues
