no fuel (pump not working)
Hello
Having trouble with my 01 GT.
There appears to be no fuel getting to the motor. With the key set to on, I get no fuel out the value on the fuel rail. Also, I do not hear the pump prime.
The fuse in the engine compartment is good (or at least looks good)
Can anyone shed some light on this or give me some suggestions on what else to look for?
Thank you
Thank you
Pop the back seat out, find the connector for the fuel pump and direct wire it to a 12V source. If it fires up then it's not the pump and you'll have to trace it back.
If it's not the pump, the fuse is good and the inertia switch isn't tripped I'm going to go with a bad Fuel Pump Relay. You can test those too.
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
