Rattling Sound When Idling
I have another issue now. I made a couple laps on a city street and after that, when I push the brakes, slowing down to a red light, and the rpms gets close to the normal idle range, the battery light turns on, then the check engine light, and the engine stalls. After that, I can start up the engine fine with no issues, it's like nothing happened. So today, I did some research which said clean the idle air control, which i did. I also changed the air filter. Hopefully this fixes the issue? After doing all that, I took it for a short drive around the neighborhood and i went to a parking lot to sit idle. There's this rattling sound that I got a video of that concerns me. I can only hear it inside the car, not in the engine bay, not outside, and the hood and body parts seem to be properly tightened. I have heard this rattling sound before i did the idle air control cleaning and filter change, but i was hoping what i did would fix it, but apparently not. I don't know if this sound is normal for v8 mustangs or if it is a concern: https://www.facebook.com/photo.php?v...20250133046189
I can't pinpoint the sound from the video however you never say if you have the SES code checked. Do you have a Diablo to check the code or did you take it to Autozone to ask them to plug in?
Also, the IAC is an electronic piece. Sometimes just cleaning it will not fix it. My IAC had to be completely replaced. I never got a SES light with mine, it just idled rough then stalled.
there are two different IAC's ford used on the New Edge. Unfortunately your year vehicle used the $85 (if I recall price) priced IAC, not the $50 one. There is a slight difference in design and I DO NOT know if either will work on your 02 or if you must stick with the more expensive one. Maybe someone else can chime in on that.
If the SES light is coming on when the car dies, then goes away when you start it back up again I doubt its throwing you a code. The light would stay on otherwise, wouldn't it?
On that rattle, is it by chance a stick shift and is the clutch pedal vibrating? My 98 sounded just like that when the TOB retainer broke and the clutch pedal was flopping around.
If not that, it's likely something up in the heater box.
jc316, it is stick shift and the clutch does feel like it is vibrating, but shouldn't the clutch have some vibration? heater box? you mean like the fan that pushes the air through the vents? That's what I was thinking at first, but the heat/ac wasn't on.
There shouldn't be much in the way of vibration in that pedal. Try pressing it in and see if the sound goes away.
Ok, I will try that when the sound comes back. So this is weird. I'm working on the Mustang, there is no check engine light, just the low coolant fluid light, but I decided to try to use my code reader. It came back with this code: http://engine-codes.com/p0457_ford.html though as far as I can tell, the gas cap is on and I don't see what a gas cap has to do with low coolant fluid.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
movielover40
09-15-2015 10:37 AM
