Knocking sound help please
Old 05-11-2014, 04:54 AM
bking2010
bking2010's Avatar
Default Knocking sound help please
Knocking sound on my 96 gt mustang. Can't figure out what it would be please help. Here is the link to the video.
http://m.youtube.com/results?q=shanaeking%20mustang%20&sm=3
bking2010 is offline
Old 05-11-2014, 01:00 PM
edwin108
edwin108's Avatar
That doesn't sound good. I would guess a rod bearing or wrist pin.
edwin108 is offline
Old 05-11-2014, 02:16 PM
JC316
JC316's Avatar
Rod knocking. Sorry. Pull the fuel injector power one at a time with it running, when it gets quieter, that will confirm the knock and tell you what cylinder it is.
JC316 is offline
Old 05-12-2014, 10:01 PM
5sp04GT
5sp04GT's Avatar
+1 def sounds like a rod
5sp04GT is offline
Old 05-13-2014, 12:18 AM
bking2010
bking2010's Avatar
Well I was really hoping it wasn't a rod =( how expensive would it be to rubuild myself or what's my best options in this situation?
Old 05-13-2014, 05:18 AM
VTX1800N1
VTX1800N1's Avatar
You can follow my parts selection here: https://mustangforums.com/forum/4-6l...-2002-a-3.html
A less expensive alternative would be to buy a reman engine. They can be had for $2 - $3K. You can also go the junkyard route but you never know what you're really getting.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 05-13-2014, 07:34 AM
bking2010
bking2010's Avatar
ok so is "Pulling the fuel injector power one at a time with its running, when it gets quieter, that will confirm the knock and tell you what cylinder it is" a positive way to check and make sure its a rod without screwing anything up completely or is there a better way? I figured if it was knocking that it would do it at an ideal as well?
Old 05-13-2014, 09:33 PM
JC316
JC316's Avatar
Yes, it's a common method of checking for a rod knock. When you disable the cylinder, it has less load and less knock.
I always go with the junkyard run if I don't plan on building it. I usually go with a crown victoria or towncar engine, they can be had for around $500.
JC316 is offline
Old 05-16-2014, 01:47 AM
bking2010
bking2010's Avatar
Well honestly all I wanted to do was throw a cam in it. I have people saying it sounds like cam phaser or flywheel/flexplate or starter loose cause it does grind sometimes when I start it. But like I said , I know very little.
Old 05-16-2014, 07:35 AM
VTX1800N1
VTX1800N1's Avatar
You don't have cam phasers in a 96 GT. If you hear rattle on start up, the gaskets on your cam chain tensioners are likely blown and will need to be replaced. Is this like a starter grinding or is it a rattle immediately after it starts?
Quick Reply: Knocking sound help please
