8 or 6 bolt flywheel?
Old 06-17-2008, 11:50 AM
2004YellowStang
2004YellowStang's Avatar
Default 8 or 6 bolt flywheel?
Is there a way to find out if I have a 6 or 8 bolt flywheel without pulling the tranny? It's a 2001 GT, any help is appreciated. I know this is kind of a dumb question but I wasn't sure if there was a specific year that it changed.
2004YellowStang is offline
Old 06-17-2008, 12:41 PM
Ryan86272
Ryan86272's Avatar
Default RE: 8 or 6 bolt flywheel?
6 BOLT FLYHWEEL= GT'S
8 BOLTS = COBRA
Ryan86272 is offline
Old 06-17-2008, 01:03 PM
Eagle2000GT
Eagle2000GT's Avatar
Is it a Windsor or Romeo motor? Early 2001s may have had Windsor motors. Windsor's are 8-bolt and Romeo's are 6-bolt. (Note: That said, I have heard that a few Windsor's were 6-bolt.)
If you're unsure of the motor, Windsor's have 13/14 bolt valve covers. Romeo's have 11 bolt valve covers.
Eagle2000GT is offline
Old 06-17-2008, 02:00 PM
oxfordgt
oxfordgt's Avatar
Holy crap you guys just hurt my head with your advise.
Look at your door sticker if the is a K under tranny then you have a later 01 model and it a romeo and a 6 bolt crank.
oxfordgt is offline
Old 06-17-2008, 02:08 PM
Ryan86272
Ryan86272's Avatar
ORIGINAL: oxfordgt
I thought 8 bolts were only on Cobras??
My GT, has 6 bolt. Tranny doesnt matter..(unless u just trying to find out Which motor his had.........) Bolts up the same my BUILT Motor with 8 bolts..
Do the 99-01's have different Flywheels?
Old 06-17-2008, 02:54 PM
oxfordgt
oxfordgt's Avatar
Yes 99-01.5 are windsors and have 8 bolt cranks. They are still cast cranks like the 6 bolt. 99% of the time a mustang with a T45 has a windsor engine in the 99-01 cars. Thats why you check for what tranny you have.
oxfordgt is offline
Old 06-17-2008, 04:24 PM
HEAVYMETALMATT
HEAVYMETALMATT's Avatar
even easier way is to look at your water pump pulley. if its concaved its a 6, if it protrudes forward its an 8, eagle200gt is right though.
HEAVYMETALMATT is offline
Old 06-17-2008, 05:12 PM
Perf_white_GT
Perf_white_GT's Avatar
8 bolt cranks in the mo funkin hizzouse!
2000 GT with a winsor motor!
Perf_white_GT is offline
Old 06-17-2008, 09:42 PM
pcs
pcs's Avatar
according to sean hyland motorsports, the 8 bolt can handle more ponies than the 6 bolt can,. though if you try to push either to the limit, you break the rods or pistons first.
pcs is offline
Old 05-14-2014, 04:44 PM
ben830
ben830's Avatar
Im Only resurrecting this thread to let everyone know that I have a Windsor with a 6 bolt crank. Long story short I ordered an 8 bolt for my 99 and when I went to put on the flywheel obviously didn't bolt on so.
ben830 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
junior04
09-28-2015 10:53 AM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
Quick Reply: 8 or 6 bolt flywheel?
