Gauge lights
RE: Gauge lights
its so easy my little sister could do it, i believe what you need is a hex key thingy, make sure you mark where your needles are because you will have to take them of. ESPECIALLY make sure the gas needle is in the right place. i made the mistake of not making sure it was correct and ended up running out of gas on my first date with my current g/f and had to call her mom to bring us some gas. like i said, it insanely easy
RE: Gauge lights
Ok, so its insanely easy. I'm not looking to change the display type, I like the black like it is. I just want to change the bulbs behind it so that it lights up blue instead of green.
Smell what I'm steppin in?
RE: Gauge lights
ORIGINAL: sm0ke
On the note of realigning needles, try to make it as simple as possible... when at full temperature, my temperature needle reads just below 1/2. Oil pressure is just over 1/2 (60% I know this for a fact), battery is about the same. For fuel, run your tank to something simple like E, 1/4, 1/2, 3/4, or full so it is easy to replace... idle is 800 RPM, easy to replace. Speedometer needle is a little trickier. Find an empty road or some empty parking lot, let the car idle in 2nd gear, which is a little over 10 MPH. Have a friend hold on to the wheel to remove some of the stupidity of looking away from the road, and let you know of impending danger and stick the needle on and check it. Use this: http://www.mustangworld.com/ourpics/fcar/dtcodes.htm set to the MPH mode to check your accuracy.
Here are a couple of pictures of mine. The blue doesn't match the green in the A/C panel, and radio, oh well though. Is that the type of color you are looking for? (You'll be stuck with white-face, those are from a Cobra)
[IMG]local://upfiles/20167/F6FF2F14FF454E7595E55CC3C448FBCB.jpg[/IMG]
[IMG]local://upfiles/20167/C2959FD8C8A743578745888B5DF47C90.jpg[/IMG]
RE: Gauge lights
hey.. i got a question on the guages.... the back light on mine is burned out or something.... like... i only see the needles light up at night... what can i do to fix that? i have aftermarket white face gauges. i took it to the dealership and they said they have to replace soem parts... i took it apart and it looks like there is 2 wires going to the white surface... does that light the white up? the previous owner put them on the car.
RE: Gauge lights
ORIGINAL: racer02GTstang
RE: Gauge lights
they are hooked up.... thats the one thing that bothers me... do i have to buy a new guage face if this one wont light up.... im gonna check the power on the two wires when i get home today just to see if its getting power.
