steering wheel shake
Old 09-21-2014, 10:28 AM
elavin20
elavin20's Avatar
Default steering wheel shake
I have a 2001 4.6L 5 speed coupe. When I get between 50-60mph my steering wheel shakes bad, but it doesn't shake before 50 or after 60mph. Also when I press my breaks my steering wheel shakes violently. I just had my tires rotated and balanced and air was checked. Someone said rotors, someone said shocks, but those are fairly new and I don't bounce around. What else could it be?
elavin20 is offline
Old 09-21-2014, 11:17 AM
dawson1112
dawson1112's Avatar
You probly either have a bad wheel bearing or tie rod ends.
dawson1112 is offline
Old 09-21-2014, 06:13 PM
tadpole1969
tadpole1969's Avatar
its either your rotors or a wheel bearing gone bad or tie rod one of the 3 , from what you said sounds like it may be a tie rod ,cause brake rotor most of the time only does this ,if its a warped rotor or applying the break ,not dureing normal driveing and no break applyed
tadpole1969 is offline
Old 09-21-2014, 07:00 PM
uberstang1
Chupacabra
uberstang1's Avatar
Should be easy to detect, check the wheels for any freeplay to determine wether its a wheelbearing, tie rod, or ball joint.
uberstang1 is offline
Old 09-22-2014, 06:57 AM
elavin20
elavin20's Avatar
It doesn't make any noise if that helps, just rattles when it bounces.
elavin20 is offline
Old 09-22-2014, 07:15 AM
tadpole1969
sounds like tie rod , just jack front end up and grab the tire on the left and rigth side . try and pull in and out on either side and see if you hear any rattleing or see any play at all in it
Old 09-22-2014, 03:28 PM
JC316
JC316's Avatar
Might be a tire balance issue too. My Firebird has developed the same damned thing, and I have replaced everything short of the control arms and I still can't get it to go away. I'm pretty much down to tires at this point.
JC316 is offline
Old 09-24-2014, 06:16 AM
tadpole1969
very true could be ,i think he just needs to take it to a shop and let them give it a good once over , i dont think they will charge to find the issue. least they dont where i take my stuff to
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
lincolnshibuya
09-24-2015 10:46 PM
stark777
09-21-2015 12:46 PM
Quick Reply: steering wheel shake
