Rag Joint
Old 10-30-2014, 06:56 PM
swarthyfellow
swarthyfellow's Avatar
Default Rag Joint
I would like to replace mine but for the life of me I can seem to find what I need. I don't want to replace the whole lower shaft just the rubber. Its the only rubber bushing I haven't replaced. Can anyone point me in the right direction.
swarthyfellow is offline
Old 10-31-2014, 05:42 AM
dawson1112
dawson1112's Avatar
I think the reason your having trouble finding one for that year is because they rarely if ever need replaced. It should last the life of the vehicle and then some.
Unless your experiencing an exorbitant amount of steering wheel play at the joint then its not worth messing with it.
dawson1112 is offline
Old 10-31-2014, 06:24 AM
swarthyfellow
Its hard to say... I am replacing other parts this weekend. I'm pretty sure based on the shape of the rubber I have taken off other parts of the car that it has to be in tough shape. Steering is has some play. After this weekend that will be the only wear part on the steering system that hasn't been replace/upgraded. I mean I assume I can replace it and don't have to do the whole shaft.
Old 10-31-2014, 04:14 PM
VTX1800N1
VTX1800N1's Avatar
If you do find that you need to replace the entire shaft: http://www.latemodelrestoration.com/...-Steering-Rack
VTX1800N1 is offline
Old 11-02-2014, 10:06 AM
uberstang1
Chupacabra
uberstang1's Avatar
just replace the shaft, if your running long tube heads u can get a solid shaft as the heat from aftermarket headers is what causes the rag join to prematurely fail.
uberstang1 is offline
Old 11-05-2014, 02:41 PM
swarthyfellow
I don't have long-tubes but I do have shorties. I still have a hard to believing a piece of rubber is really going to last this long. At this point it is the only part of the steering system that hasn't been replaced. Maybe I will just replace the whole column in the springtime. I just figured there would be a cheaper solution with replacing rag joint only.
mtgldr
02-03-2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
marc954
09-29-2015 11:18 AM
gagemcc
09-22-2015 09:43 AM
trashxtrash
09-20-2015 10:49 PM
Quick Reply: Rag Joint
