Mach 460 System Problems. Only tweeters are working?
Old 01-01-2015, 02:35 PM
dakman96
dakman96's Avatar
Originally Posted by Chromeshadow
Are you using the sub RCAs from the head? Does the head have a menu that turns the
se off and on? It does sound to me that the factory amps might be out, are they getting DC power? Are they getting warm?
When you have time-this will be a good test
I've got an update with good news, bad news, and a little bit of funny news... Turns out through my stupidity I had the RCA cables plugged into the wrong slot the whole time After correcting that, I got power going to my rear woofers again. I now have half of my bass back, but unfortunately my front door speakers STILL don't work (it was like this still when I bought it). I'm beginning to think my amp is bad, how would I test this? I have a 12v power checker, should I touch each pin of the amp and see if it works? Or could I even hardwire these speakers somehow? Thanks in advance and here's pics to clear it up a little more.
dakman96 is offline
Old 01-01-2015, 04:18 PM
Chromeshadow
Chromeshadow's Avatar
That is good news, finding a swap like that one can be tough. Good work going back over everything.
Do you have one amp or two?
If you have two you might be able to switch them out.
The 12V tester won't be much help other that making sure it has 12 power.
Chromeshadow is offline
Old 01-01-2015, 05:40 PM
dakman96
dakman96's Avatar
I believe there are actually 3 amps, 1 hidden behind the stereo (that from what I've read is unreachable) and then two in the trunk. I will try switching them out tomorrow and seeing if I can get the front speakers working. Also I should note that when I plugged the RCA cables in their proper spot, it's the white one that isn't working if that helps at all. Thanks for the advice and I'll be testing the amps tomorrow!
dakman96 is offline
dubarado
12-23-2015 01:16 PM
JonnyBlazeGT
11-03-2015 01:10 AM
steelers743
08-31-2015 07:16 AM
DrunknRuckus
08-23-2015 10:05 AM
iamgobono
08-16-2015 10:50 PM
Quick Reply: Mach 460 System Problems. Only tweeters are working?
