Front Brakes stuck 04 GT Guaranteed to stump you!
Old 04-01-2015, 10:25 AM
swarthyfellow
swarthyfellow's Avatar
I mean if everything else is right, why not just block sand the pads to take like .005" from each.
swarthyfellow is offline
Old 04-03-2015, 12:14 AM
T04SonicGT
T04SonicGT's Avatar
Originally Posted by Z28KLR
What brand pads? I've seen quite a few complaints over the years where the scenario is some guy gets replacement pads from the local parts store and they are too thick.
I will say though that I've bought lots of pads for lots of vehicles over the years from Autozone etc and never had that problem, so when I see the above scenario I always have doubts that there's another issue such as the guy doesn't know how to compress the caliper all the way, but there have been a couple times where it was somebody I was pretty sure knew wtf they were doing and they reported having to sand the pads down in order to get a proper fit, or even comparing the pads to another stores brand and confirming that they were too thick.
They're from advance auto. They're the highest quality. I've looked at every brand at every local store...carquest, auto zone, oreillys, they all have the same thickness of pads and rotors. Maybe I will have him sand the pads a little. I've also thought of turning the rotors but that seems silly to turn brand new rotors
T04SonicGT is offline
Old 04-03-2015, 12:19 AM
T04SonicGT
T04SonicGT's Avatar
I'm gonna have him try that. I'll let u know how it goes. Thanks for the help. And thanks everyone else who reads this topic.
Old 04-04-2015, 08:16 PM
mustangman02232
mustangman02232's Avatar
As cheap as they are, I would try replacing the rubber lines (Upgrade to the braided ones if you can afford it), the rubber ones sometimes collapse in and restrict the fluid
mustangman02232 is offline
Old 04-05-2015, 08:49 AM
Chromeshadow
Chromeshadow's Avatar
I'd get a new mechanic.
Chromeshadow is offline
Old 04-06-2015, 10:40 AM
jimkaray
jimkaray's Avatar
With everything new I'm going to reject all the past history at this point since I can see no reason for it to be a factor. Seems that piston compression is not the issue since you had yet to connect the lines.
To rule out the bracket have you tried slip the caliper on the rotor without the bracket?
Both sides have the problem - pad thickness checks out, calipers check out, rotor thickness too. I'm thinking the new rotors may be warped out of the box. Quality control ain't what it used to be. Hopefully the store you bought them from turns rotors. Set them up on their lathe and check them out. The tolerance is real tight on new pads and rotors so if they were part of bad batch and are a little off that could be your problem.
jimkaray is offline
Galactic
04-29-2019 02:56 PM
Granatelli Sales
03-25-2016 08:01 PM
DoctorScary
09-09-2015 07:53 AM
09-08-2015 11:50 AM
Quick Reply: Front Brakes stuck 04 GT Guaranteed to stump you!
