Transmission? Rear? Etc?
Okay I have a quick opion from someone....Okay I have a 96 Auto Gt w/overdrive.
Takeing off it... shifts once....okay then shifts again with the overdrive off....then driving along its like it going over a ruff road like it slides into gear but doesnt shift again. The car runs fine.
Okay what do you think?
RE: Transmission? Rear? Etc?
It is most likley your overdrive gear is going or is going bad. Sounds like it it time for a re-build on that trans. If that is what you do I would suggest that you add a trans. cooler and If you want you can get a shift kit and a higher stall torque convertor.
09-01-2015 08:16 PM
